support for PA-MC-2T3+
fprime7
HI
I have a 7204 VXR router running 12.2(3) and want to install the PA-MC-2T3+ linecard.
After checking the following
CISCO 7000 FAMILY PORT ADAPTER PLATFORM AND IOS RELEASE SUPPORT MATRIX
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_brochure0900aecd804b1a64.html
IOS 12.2
PA-MC-2T3+ 7200**
What does the ** next to 7200 indicate ?
I will also be running 3 ? PA-MC-8TE1+ linecards, anything to watch out for?
Frank
b.hsu
Level 5
Level 5
Based on the ANSI T1.231 specification a T3 controller should not react to an alarm (LOF, LOS, AIS) unless the alarm persists for 2 +/-0.5 seconds.IOS which has the fix for 7204 models are 12.1(23.01)E 12.0(29.01)S 12.3(09.07)T 12.2(24.08)S 12.2(24a) 012.003(009.007) 012.002(024.008) 12.2(19c).Upgrade to this IOS to fix this problem.That is the reason ** is seen.Refer the URL
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_field_notice09186a00802ff01d.shtml
b.hsu
Level 5
Level 5
