Supported VRF amount on ISR C1117-4PM
ernjoe
Hey,
I tried to scan the web and multiple datasheets, but cant quite find an answer for this one;
how many VRF:s does the Cisco C1117-4PM support? Is it dependant on license?
Thanks for your help!
7 Replies 7
Leo Laohoo
Depends on the memory and the WAN speed.
Exactly how many VRF are you intending to enable and what is the WAN speed?
ernjoe
Currently 8-10 VRFs are in thoughts. WAN speed 100M (1Gbit/s media)
Which is the WAN speed, 100 Mbps or 1 Gbps?
ernjoe
100M. I appreciate the help very much, would you happen to have a chart or something of the sort where I could see the info myself too?
100 Mbps and 8 VRF is tolerable.
ernjoe
Hey, thank you. Do you have any links to any documentation I could refer to that shows the technical limitations of the device?
Contact the sales team.
Go to the Data Sheet.  On the lower right-hand corner is a "chat" icon.  Click on that.  Fill in the details and wait for someone from Sales to contact you.
