Suspected problem with BGP route advertisement
Lionel271
Hi there!
I am experiencing a problem which I suspect involves an issue with route advertisement.
The setup is as follows:
Device A 10.0.154.2/25
    gateway 10.0.154.1
Router A interface 1 10.0.154.1/25 interface 2 10.0.154.250/29
    interface 1 is connected to network with Device A, interface 2 is connected to network with router B
    EIGRP
Router B interface 1 10.0.154.249/29 interface 2 10.0.155.234/29
    interface 1 is connected to network with router A, interface 2 is connected to network with router C
    BGP neighbor 10.0.155.233 (router C)
    EIGRP (redistribute into BGP)
Router C interface 10.0.155.233/29
    has routes to devices on 192.168.1.64/27 and 192.168.3.64/27
    exact configuration unknown, but assumed to be correct
The ultimate requirement is that Device A is able to reach devices on 192.168.1.64/27 and vice versa. Only the routes required to reach this device are required to be advertised into the BGP table on 10.0.155.233.
Both device A and router A successfully connect to 10.0.155.234 (router B), but can't connect to 10.0.155.233 (router C) or further. Traceroute hops to 10.0.155.1, then 10.0.155.249 and stops here.
Router B reaches 10.0.155.233 (router C), and traceroute follows the router there as received over BGP.
Relevant config on router B:
router eigrp 100
  network 10.0.0.0
  network 192.168.0.0
  redistribute bgp 3000
router bgp 3000
  neighbor 10.0.155.233 remote-as 5000
  address-family ipv4
    network 10.0.152.0
    network 10.0.153.0
    network 10.0.154.0
    redistribute connected
    redistribute static
    redistribute eigrp 100
    neighbor 10.0.155.233 activate
    neighbor 10.0.155.233 route-map net1 out
route-map net1 permit 10
 match ip address 1
access-list 1 permit 10.0.154.0 0.0.0.255
#show ip bgp neighbor 10.0.155.233 advertised-routes
BGP table version is 97, local router ID is 172.16.186.250
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
 *>  10.0.154.0/25 10.0.154.250   26882560         32768 ?
 *>  10.0.154.248/29
                       0.0.0.0                  0         32768 ?
Total number of prefixes 2
#show ip bgp neighbor 10.0.155.233 routes
 *>  192.168.1.64/27   10.0.155.233                        0 5000 i
 *>  192.168.3.64/27   10.0.155.233                        0 5000 i
Config on router A:
router eigrp 100
  network 10.0.0.0
  network 192.168.186.0
  network 192.168.17.0
  no auto-summary
router eigrp 200
  redistribute static
  -- unrelated internal networks --
  no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.4.137
ip route 172.16.154.80 255.255.255.248 10.0.154.249
-- more unrelated routes --
#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.4.137 to network 0.0.0.0
     10.0.0.0/16 is variably subnetted, 5 subnets, 2 masks
C       10.0.154.0/25 is directly connected, FastEthernet0/1.21
D       10.0.155.240/29
           [90/297244672] via 10.0.154.249, 18:33:46, Tunnel0
D       10.0.155.248/29
C       10.0.154.248/29 is directly connected, Tunnel0
D       10.0.155.232/29
-- lots of unrelated routes removed --
     172.16.0.0/29 is subnetted, 1 subnets
S       172.16.154.80 [1/0] via 10.0.154.249
S*   0.0.0.0/0 [1/0] via 192.168.4.137
Can some genius shed some light on what's going wrong?
Thanks in advance!
You're missing default-metric in EIGRP config. EIGRP does not redistribute BGP routes on R2. You need to set it in either of 3 ways:
redistribute command with route-map
redistribute command with default-metric
"standalone" default-metric EIGRP command
5 Replies 5
Lionel271
There is another issue here as well:
Router A is not receiving the routes to 192.168.1.64/27 and 192.168.3.64/27 from router B over EIGRP, even though redistribute bgp is enabled on router B.
This would not explain why 10.0.155.233 is inaccessible though.
Thank you, Michal! The problem is now partially resolved.
I can confirm that adding a default-metric solved the route redistribution problem.
I'm receiving all the BGP entries over EIGRP now, but I'm still unable to reach 10.0.155.233.
I suspect that this issue, which is the big problem, is related to the BGP configuration itself. The route to it is advertised over EIGRP because I can see it in the routing table (and I can reach the router on 10.0.155.234).
I think that the router at 10.0.155.233 doesn't have a route back to the rest of the network, yet it shows in the advertised-routes table. Unfortunately, I have no access to that router, so I cannot look at the tables there. I can only troubleshoot it from the other end.
Post the updated config of both A & B routers, please. And "show ip route" output of relevant prefixes.
And I thought you were trying to reach 192.168.1.64/27 network, not 10.0.155.233.
10.0.155.233 is a router sitting in front of 192.168.1.64/27, so my reasoning was that if I can't reach that, I won't go further.
"show ip route" gives thousands of pages worth of output. There are about 650k entries in the BGP table :-).
Somehow this has starting working though. I think the problem was on the other end at all, so the only problem here appears to be the metric issue you brought up earlier.
