SW & IPS Problem
tareqrebhi
Dear I need to run my IPS i configured my sitch 3560 but when i entered this command :
monitor session 1 destination interface Fa0/24i lost the connection with IPS.
i put the monitoring IPS port at SW port/24 ....
what is the problem?
Pavel Bykov
Level 5
Level 5
Whenever port is destination of a span port it enters a monitoring state. This port receives a copy of all packets that are traveling through SOURCE ports/vlans.
This is standard function.
You have to communicate with your IPS some other way, if it's a span destination.
