switch 3850 and WLC
mireille.saade
Dear support,
As per the datasheet of 3850 switch, it states that it includes wireless controller capabilities. can i use the integrated controller as a mobility controller for a small branch (or should i add another 2504 WLC)? kindly advise..
Best Regards
Mireille
2 Accepted Solutions
Bilal Nawaz
Hello, From Cisco's documentation, the answer is yes, you can use the 3850 as mobility controller.
• Mobility agent (MA):  This is the default mode in which the Cisco Catalyst 3850 switch ships.  In this mode the switch is capable of terminating the CAPWAP tunnels  from the access points and providing wireless connectivity to wireless  clients. Maintaining wireless client databases and configuring and  enforcing security and QoS policies for wireless clients and access  points can be enforced in this mode. No additional license on top of IP  Base is required to operate in the mobility agent mode.
Mobility controller (MC):  In this mode, the Cisco Catalyst 3850 switch can perform all the  mobility agent tasks in addition to mobility coordination, radio  resource management (RRM), and Cisco CleanAir® coordination within a mobility subdomain. The mobility controller mode  can be enabled on the switch CLI. IP Base license level is required when  the Cisco Catalyst 3850 switch is acting as the mobility controller.  A centrally located Cisco 5508 Wireless LAN Controller (WLC 5508), Cisco  Wireless Services Module 2 (WiSM2) (when running AireOS Version 7.3),  and Wireless LAN Controller 5760 can also perform this role for larger  deployments.
With mobility agents located in the wiring closets providing 40 Gbps of wireless per switch (n x 40 Gbps for a stack of n  switches) and mobility controllers managing some of the central  wireless functions, the converged access-based wireless deployment  provides best-in-class scalability for wireless and significantly  improved wireless throughput.
Please see here for more details:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/product_bulletin_c25-720777.html
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Yes, no need according to Cisco, the document states that:
So this suggests that the 3850 will be able to carry the MC role just standalone. For larger deployments use the WLC's.
Hope this helps
Bilal Nawaz
Hope this helps
so no need for any additional WLC, right?
Hope this helps
thank you
