Switch connected to ASA can't be pinged from inside network
DaveU
We have two switches on our network which is unreachable when pinging from our servers.
Switch is on 192.168.5.x/24 subnet
Servers is on 192.168.1.x/24 subnet
The setup is ASA --> SW1 --> SW2 --> Servers. (See diagram uploaded)
Our goal is to make the switches reachable from our servers. I tried pinging the switch from ASA which i get replies but pinging the ASA from switch fails.
Everything works fine on the network, we just need to make the servers able to ping the switches.
Hello
Why do you have two MGT vlans ?
192.168.5.0/24 - vlan 5
192.168.100.0/24 - vlan 100
On your switches you show as having two L3 interfaces in the above vlans , which isnt a problem but it isnt necessary.
As you OP mentioned communication between vlan 5(mgt) and Vlan10 (server vlan) i would suggest to use vlan 5 network as the gateway, apply the below and test again.
Switch1 & 2
conf t
ip default-gateway 192.168.5.1
Kind Regards
Paul
6 Replies 6
Hello
Your switches dont have a default-gateway or a default route so outside it own vlans it wont be able to respond? -  Try adding this.
Kind Regards
Paul
Which default-gateway should I add?
192.168.5.1 or 192.168.1.1 ?
Btw, What is the recommended way for me to do this? Should I add ip route or ip default-gateway?
Hello
Switch1 & 2
conf t
Kind Regards
Paul
It worked! Thank you!
Netlabbuilder
I hope I correctly understand your network setup.
  • Your switches are simply L2 switches, thus you should have only one SVI (for the Switch/Network Management purpose). You should choose either SVI for VLAN 5 or SVI for VLAN 100, but not both to be used on your L2 switches (as in the configuration). The other SVI/VLAN should be removed/deleted from your L2 switches and on ASA.
  • Let us assume that you choose VLAN 5 and Interface VLAN 5 as your Network Management SVI/VLAN (as shown in the network diagram), you can use the IP address of 192.168.5.1 on ASA sub-interface G1/2.5 as the default-gateway for your switches (with command ip default-gateway 192.168.5.1).
