Switch is reachable from any subnet or unused IP
tbryant97
Cisco 9600 core switch is reachable from any IP in our subnet. The main interface is 172.18.112.1 which I use to access the switch web interface. Upon running NMAP scans the switch shows up multiple times on the scans throwing them off. I can access any IP such as 172.18.43.1 below.
There is no interface defined for that subnet anywhere in our network.
Rapid7/NMAP Scan:
6 Replies 6
Mark Elsen
 - Check running config and or apply ACL(s) for restricting management access (HTTP or other) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Existing access-list:
Extended IP access list IP-Adm-V4-Int-ACL-global
10 permit tcp any any eq www
20 permit tcp any any eq 443
Extended IP access list implicit_deny
10 deny ip any any
Extended IP access list implicit_permit
10 permit ip any any
Extended IP access list meraki-fqdn-dns
Extended IP access list preauth_v4
10 permit udp any any eq domain
20 permit tcp any any eq domain
30 permit udp any eq bootps any
40 permit udp any any eq bootpc
50 permit udp any eq bootpc any
60 deny ip any any
Extended IP access list sl_def_acl
10 deny tcp any any eq telnet
20 deny tcp any any eq www (2010 matches)
30 deny tcp any any eq 22 (312 matches)
40 permit ip any any (1512 matches)
IPv6 access list implicit_deny_v6
deny ipv6 any any sequence 10
IPv6 access list implicit_permit_v6
permit ipv6 any any sequence 10
IPv6 access list preauth_v6
permit udp any any eq domain sequence 10
permit tcp any any eq domain sequence 20
permit icmp any any nd-ns sequence 30
permit icmp any any nd-na sequence 40
permit icmp any any router-solicitation sequence 50
permit icmp any any router-advertisement sequence 60
permit icmp any any redirect sequence 70
permit udp any eq 547 any eq 546 sequence 80
permit udp any eq 546 any eq 547 sequence 90
deny ipv6 any any sequence 100
Not sure how this helps, I can hit the webui of the switch from an IP that the switch doesn't have defined in its config.
are you run NAT ?
are you have static route toward SW IP ?
Only NAT is behind our firewall but there is not route directly to the core switch from there.
On the switch, there is a route for "ip route 172.18.0.0 255.255.0.0 172.18.112.0"
Would this ip route cause the switch HTTP interface to be broadcasted to all network IP's?
