Switch Location Name
Visauk47
Hi All,
I copied the config of an Old switch to configure a new switch but when I login through https:// IP into the new switch, its showing the old location, check the screenshot attached, Is there any command to add the new location of the switch.
Please let me know.
Vis
Hello
Need to change snmp-server location xx
Kind Regards
Paul
Hello
Kind Regards
Paul
Thanks Paul, I changed the name and can see the new name on the web GUI :)
if you can access the switch with the WebGUI, can you actually open the web console ? If so, check if there is a SNMP System Summary page, and a customer-definable 'Location' text box, which lets you set the switch location...
Hi Georg,
Issue was with the Old name mentioned on the smtp-server location config, which I have changed.
V
