Switch Modem :Cisco 2960-S Series POE
it.ne
Dear Team,
We have an issue to log in(though we type correct credentials it doesn’t log in) using Cisco Network Assistant for the model Cisco 2960-S Series POE.
Some of the community support says this  model is not supported for cisco network assistance, hence kindly revert back with appropriate answer.
Router Details:
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 6C:99:89:23:F1:80
Motherboard assembly number     : 73-11908-09
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC17500WNM
Power supply serial number      : LIT174400XW
Model revision number           : H0
Motherboard revision number     : A0
Model number                    : WS-C2960S-24PS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC17493F2N
System serial number            : FOC1750W4ZE
Top Assembly Part Number        : 800-30945-04
Top Assembly Revision Number    : C0
Version ID                      : V04
CLEI Code Number                : COMGE00ARD
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24PS-L   12.2(55)SE7           C2960S-UNIVERSALK9-M
Leo Laohoo
CNA will support 2960S.  The question is WHAT VERSION is CNA.  Read the Release Notes (HERE) and Table 1 should list down all the supported models.
Thank You,
Abhinandan
Can you please mark this thread as "Answered"?
