Showing results forĀ
Search instead forĀ
Did you mean:Ā
Switch port supported in Cisco ISR 4431 (built-in WAN/LAN ports)
terryzhao
Cisco Support,
Please kindly help to clarify the technical feasibility of the Cisco ISR 4431.
  • Whether the built-in WAN/LAN port could be configured as switch port in dedicated access VLAN?
  • Whether the built-in WAN/LAN ports could be configured to running for L2 switching?
Mark Malone
No the 4331 is a dedicated ISR router pure layer 3 all ports that come as standard  , you can purchase a switch module for them though
Here are the supported modules list for 4000 series
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Glenn Martin
Moving this discussion to the Network Infrastructure>WAN Support Forum
