switch provision command in 3650 switch stack
lkadlik
So I read the following:
"You cannot use the switch current-stack-member-number renumber new-stack-member-number global configuration command on a provisioned switch. If you do, the command is rejected."
This made me wonder about the switch provision command.  I was trying to find some more information about it without much success.  I was hoping someone could tell me if it needs to be on stack, what the pros are to having it there and what the cons are of removing it off a 3650 switch stack?
command ex  switch 1 provision ws-c3650-48pd
Also, I have been told when a second 1025W power supply is added to the switches in the stack it will effectively change them to the FD model.  If the pd model is listed will it be an issue if a time comes when a second power supply needs to be added to the switch ?
Thank you.
0 Replies 0
