Switch stuck in switch: prompt
mukeshpal
Hi can anybody help the below mentioned error. Actually I was doing ios upgradation in cisco 2950 switch. and before that I ahve delete the existing ios image from the switch and once new ios image uploaded then I reloaded, but after that switch is stuck on switch: prompt. its not booting, once i checked through:
sh dir flash: command no ios is present in the switch
so after that i have planned through xmodem to put ios image into switch but once i try I am facing the below problem
pls help
switch:
switch:
switch:
switch: copy xmodem flash
xmodem: permission denied
switch:
switch:
switch: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
bs[3]: (read-only)
switch:
Regards...Mukesh
Amit Singh
Mukesh,
You are actually giving a wrong Sytax when copying the file:
The right command would be :
switch: copy xmodem: flash:c2950-i6q4l2-mz.121-19.EA1c.bin
Once you hit enter after this command, you'll have to do the transfer procedure from the
X-modem on hyperterminal window.
Here's a link explaining the complete procedure
http://www.cisco.com/warp/customer/473/192.html
HTH,Please rate if it does.
-amit singh
Amit
You are right, actually i was using copy xmodem flash: command instead of copy xmodem: flash:
Now its working fine, thanks.
Regards..Mukesh
Amit Singh
Mukesh,
Check the link below:
http://www.cisco.com/warp/public/473/192.html
-amit singh
