Switch unable to ping, but connected host able to.
codemsittc
Hi guys,
I have a weird situation as per the subject title. so this is whats going on:
NOTE: FIREWALL ALLOWS ANY ANY DURING MY TEST
So the thing i've done a SPAN and monitor on vlan 100
I found out that whenever i do a ping test from 2960 switch to 192.168.1.14 (firewall internal interface), wireshark shows "who is 192.168.1.14, tell 192.168.1.11" and then immediately i get a ARP reply from the firewall telling the 2960 switch the correct MAC address.
HOWEVER!!!! the ping still fail the full 5 times, and i also got the same ARP messages 5 times.
Anyone able to advise on the above? It seems so straightforward, but it just doesn't seems to work. Even the ARP request and reply make sense to me.
Also, when i use my laptop to ping the default gateway, which is the firewall internal interface, it is successful. But from the 2960 switch CLI, it just fails. I've tried removing the ip default gateway command on the switch, but it doesn't resolve the issue too.
the 2960 switches cannot ping 192.168.1.14, which is the virtual IP. Can they ping the IP addresses of the physical firewall interfaces ? How did you set the HA cluster up ?
5 Replies 5
what about the other way round, can you ping the switch from the firewall ?
I am unable to ping the 2960 switch interface vlan 100 (192.168.1.11). (NOTE THAT I'VE ALLOWED ANY ANY)
However, i am able to ping the 3850 switch int vlan 10.
I've edited and updated the post with a diagram so correctly illustrate the situation too.
Hi Georg,
I managed to get the solution all worked out.
I've found out the problem is with the firewall. The cluster IP doesn't seem to work. But the physical IP does.
It seems that there may have been some issue with the physical port.
Thanks anyway.
