Switching between ap# and router#
Andrew Duffield
I have configured my Cisco 887VAMW with ADSL and Wifi but the only way I can configure the ap and router separately is to be connected to the router by ssh and the ap via console cable.
When at the ap# prompt, how do I get back to the router#?
I have tried the instructions on cisco.com:
Closing the Session
To close the session between the wireless device and the router’s console, perform both of the following steps.
Wireless Device
1. Control-Shift-6 x
Router
2. disconnect
3. Press Enter twice.
But it doesnt work....help!!!
LJ Gabrillo
Level 5
Level 5
When you are in router# mode in order to enter ap# mode:
cmd: #service-module wlan-ap 0 session  -of course Im sure you have convered this
from ap# to router#
PRESS: CTRL+SHIFT+6, let go, then just press X
-A line should appear on the cmd you did
-Press enter once!
LJ Gabrillo
Level 5
Level 5
from ap# to router#
-Press enter once!
