Switchport Security on 3845 Router
missiongeek
Greetings All,
I have a pair of 3845 series routers. I am trying to enable Switchport Security on my Switch Module. Is it possible to do it? I have 1 2900 and 3500 series switch and i am able to do it with no problem.
The port I am attempting to enable port security has been made into an access port. I'm not getting any Port Security or switchport security options.
Please Help.
Mauricio
Edison Ortiz
Mauricio,
You must have the old generation switch modules, the new generation supports Port Security:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d15f.html
HTH,
__
Edison.
