We have faced an Switchover in our 7606 router for unknown reason.
SWO to standby than reboot back to active one.
Aug 1 21:45:13 UTC: %PFREDUN-SP-STDBY-6-ACTIVE: Initializing as ACTIVE processor
Aug 1 21:45:13 UTC: %FABRIC-SP-STDBY-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
Aug 1 21:45:14 UTC: %SYS-SP-STDBY-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Aug 1 21:45:14 UTC: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Switchover)
Aug 1 21:46:48 UTC: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
Aug 1 21:46:49 UTC: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Aug 1 21:46:52 UTC: %PFINIT-SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router.
Aug 1 21:47:15 UTC: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
Aug 1 21:47:15 UTC: %FABRIC-SP-5-FABRIC_MODULE_BACKUP: The Switch Fabric Module in slot 6 became standby
Aug 1 21:47:16 UTC: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
Aug 1 21:47:20 UTC: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
Aug 1 21:47:20 UTC: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
Aug 1 18:47:27.333: SP: SP detected RP/Draco rebooting, resetting SP
DHKC-R76-01#sh module
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP JAF1205BFJM
2 0 4-subslot SPA Interface Processor-200 7600-SIP-200 JAE12088TA8
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE JAE12088VUP
6 2 Route Switch Processor 720 (Hot) RSP720-3C-GE SAL1551Z508
DHKC-R76-01#sh redundancy states
my state = 13 -ACTIVE
peer state = 8 -STANDBY HOT
Mode = Duplex
Unit = Primary
Unit ID = 5
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured) = sso
Redundancy State = sso
Your help is appreciated.
Ahmed
