%SYSLOG-6-SYSTEM_MSG : Logfile wrapped-around after exceeding max-size
SR70982
Observing these logs
%SYSLOG-6-SYSTEM_MSG : Logfile wrapped-around after exceeding max-size   on the nexus device
Can anyone advise what are the reasons for this appearance . I believe this may be the designed behavior but just trying to search for more information or doc for this.
as far as I recall, this has something to do with the log file size. The command:
show logging info
shows you what is currently configured. You can change the logging file size per severity level with the command:
NX(config)# logging logfile logfile-name severity-level [ size bytes ]
Have a look at the document linked below for reference:
Cisco Nexus 5000 Series NX-OS Software Configuration Guide - Configuring System Message Logging [Cisco Nexus 5000 Series Switches] - Cisco
show logging info
