Syslog Filtering IOS
tahscolony
Is there any way to filter out ACL logs from the buffer so only messages about interface drops or OSFP peer drops are logged?  On an ASA I know I can filter out specific messages and send to a syslog server, is there something similar in IOS?
Vinit Jain
I believe you can achieve some level of filtering using logging discriminator command.
Please check the below CCO documentation for reference:
http://www.cisco.com/c/en/us/td/docs/ios/netmgmt/command/reference/nm_book/nm_09.html#wp1062700
Hope this helps.
Vinit
PS : Please do rate the post if you find them useful.
--Vinit
Thanks, I did see that document, but I didn't see any configuration examples that showed the various commands.
There will always be some difference between IOS features and ASA features but I think this doc shows what you were looking for (partially if not completely).
Please let me know if you have any more questions. Also, please join me on Ask The Expert discussion on Router and IOS Architecture and Troubleshooting Unexpected reboots on Cisco Routers at below link:
https://supportforums.cisco.com/discussion/12516901/ask-expert-router-ios-architecture-and-unexpected-reboots-routers
Vinit
PS : please mark the question as answered if your query has been answered.
--Vinit
