syslog message
maximusadonis
Hi pls guide me with the meaning of this error message that i found to be repeating in my log file
- VTP protocol user notification: Error detected in VTP Digest for VTP Domain Index 1----
what does this mean.
Thanks & regards'
Max
Georg Pauwen
Hello Max,
most likely, the VTP password is not set consistently throughout your VTP domain. Make sure that all your switches with the VTP domain use the same password.
You also might want to check this link:
Troubleshooting VTP Configuration Digest Errors Seen in the show vtp statistics Command
http://www.cisco.com/warp/public/473/21.html#ts_vtp_cfg_digest
HTH,
GP
