System returned to ROM by bus error
aruldaspr
hi all
can anybody help to solve the reson for getting error message like System returned to ROM by bus error at PC 0x6002AC04, address 0xB0D0AFD at 14:28:47 .
suggest you upgrade to 12.4(16) that has many many bug fixes.
Chances are it won't crash anymore.
But if it does, it can be diagnosed with the confidence of having a solid code base.
7 Replies 7
paolo bevilacqua
Software crash. What IOS are you running?
You _may_ get a clue about the bug if you have acces to CCO customer level and use the stack decoder tool.
hi
am using
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(1a), RELEASE SOFTWARE (fc2)
hi
what is the cause for this reson. is it any ios bug or any kind of Dos attacks
I don't think it's DoS. I know a command that does this, but the user would have to log in to the router.
Generally DoS will overload the router beyond it's capacity, not restart it
aruldaspr
I agree with Pavlo that this is almost certainly an IOS bug and not a DOS attack. Without some more details (complete show version, show stack, show tech) we can not tell. But that version of code is very old (and very early in the release level) and a code upgrade is certainly the best next step.
Rick
Rick
Not only 12.4(1a) is old, is also DF (deferral) because of some bad bug.
I've always thought the routers should come with a sticker on the front... "upgrade me often" :)
