System returned to ROM by processor memory parity error at PC 0x61885800,
Asim Afzal
I have a router rebooted and  show version shows its parity error.Is this software or hardware bug
sh ver
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(24)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 09-Sep-12 05:58 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
AE_DXB_DIF_T1_VG_L04_02 uptime is 1 week, 6 days, 18 hours, 57 minutes
System returned to ROM by processor memory parity error at PC 0x61885800, address 0x0 at 14:31:09 UTC Thu Jun 5 2014
System restarted at 14:33:30 UTC Thu Jun 5 2014
System image file is "flash:c3845-spservicesk9-mz.124-24.T8.bin"
 --More--
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 216064K/46080K bytes of memory.
Processor board ID FHK1039F1DP
2 Gigabit Ethernet interfaces
124 Serial interfaces
7 Channelized/Clear E1/PRI ports
8 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Leo Laohoo
Could be an IOS bug.
Try upgrading the IOS to a more stable "M" train.
