T-1 Configuration
rayroyaleverest
What equipment will I need to connect a LAN to a T-1 connection?
5 Replies 5
Giuseppe Larosa
Hello Ray,
a router is needed here or some form of lan extender over a T1 link
see for example
http://www.truedataonline.com/xq/asp/rvdymtx.NTZ900040PTNE1500-KIT1US/file.item/itemID.TNE1500-KIT1US/catID.522/qx/index.htm
you need two of these boxes one on each side
Hope to help
Giuseppe
Can a CSU be adequate?
No, you need a router.
Can you provide a link to a diagram showing how to set up a T-1 connection?
If you never did networking before, youi can begin with primer like this or many others that you can find:
http://www.cisco.com/en/US/docs/routers/access/2500/software/user/guide/techovr.html
