T1 / PRI drops occassionally (AIS detected)
Frank den Haan
Level 4
Level 4
For the last few months, we have been experiencing occassional, brief drops on one of our T1 / PRI circuits. It's probably once every 3 weeks or so. Not too frequent, but nevertheless we would like it resolved.
It's connected to a Cisco 2851 with IOS c2800nm-spservicesk9-mz.124-24.T5.bin
Actions taken on our end:
- Replaced VWIC-1MFT-T1 card
- Changed cable from the VWIC-1MFT-T1 card to the Telco's PRI circuit/card.
- Router has been reloaded
Telco's actions:
- Changed cable pair several times
- Actually installed a new PRI
- Confirmed framing and line code settings are the same as our equipment: Framing is ESF, Line Code is B8ZS, Clock Source is Line
But, it's still happening. The configuration at this problematic site is the same as our many other sites with PRIs/Gateways.
Although I am currently taking the issue up with the Telco yet again, I was wondering if there is anything else I could do on my end to troubleshoot this. Any help is appreciated, thanks!
Recent sh log output:
            Feb  1 05:24:51.811 AST: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to down (AIS detected)
Feb  1 05:24:51.815 AST: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to down
Feb  1 05:24:52.063 AST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller T1 0/0/0
Feb  1 05:24:53.811 AST: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to down
Feb  1 05:25:02.311 AST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller T1 0/0/0
Feb  1 05:25:02.311 AST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Feb  1 05:25:39.811 AST: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to up
Feb  1 05:25:40.815 AST: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to up
Feb  1 05:25:41.811 AST: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to up
Feb  1 05:25:50.311 AST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Feb  1 05:34:31.814 AST: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to down (AIS detected)
Feb  1 05:34:31.818 AST: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to down
Feb  1 05:34:31.822 AST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller T1 0/0/0
Feb  1 05:34:33.814 AST: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to down
Feb  1 05:34:42.074 AST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller T1 0/0/0
Feb  1 05:34:42.074 AST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Feb  1 05:35:16.814 AST: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to up
Feb  1 05:35:17.818 AST: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to up
Feb  1 05:35:18.814 AST: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to up
Feb  1 05:35:27.074 AST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Feb  1 05:41:55.816 AST: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to down (AIS detected)
Feb  1 05:41:55.820 AST: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to down
Feb  1 05:41:55.836 AST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller T1 0/0/0
Feb  1 05:41:57.816 AST: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to down
Feb  1 05:42:06.084 AST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller T1 0/0/0
Feb  1 05:42:06.084 AST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Feb  1 05:42:41.816 AST: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to up
Feb  1 05:42:42.824 AST: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to up
            Feb  1 05:42:43.816 AST: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to up
            Feb  1 05:42:52.084 AST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
_________________
Router name#sh int serial 0/0/0:23
Serial0/0/0:23 is up, line protocol is up (spoofing)
  Hardware is DSX1
  Description: XXXXXXXXXXXXX
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
     reliability 253/255, txload 1/255, rxload 1/255
  Encapsulation HDLC, loopback not set
  Last input 00:00:27, output never, output hang never
  Last clearing of "show interface" counters 6w0d
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     180498 packets input, 1062948 bytes, 0 no buffer
     Received 0 broadcasts, 3324 runts, 0 giants, 0 throttles
     9407 input errors, 9407 CRC, 0 frame, 0 overrun, 0 ignored, 2232 abort
     180505 packets output, 1140153 bytes, 0 underruns
     0 unknown protocol drops
     6 carrier transitions
  Timeslot(s) Used:24, SCC: 0, Transmitter delay is 0 flags
________________________
Router name#sh controller t1 0/0/0
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Description: XXXXXXXXXXXXXXXXX
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (825 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
     0 Line Code Violations, 41 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 9 Degraded Mins
     15 Errored Secs, 8 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 7:
     2 Line Code Violations, 1412 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 7 Degraded Mins
     14 Errored Secs, 10 Bursty Err Secs, 1 Severely Err Secs, 18 Unavail Secs
  Data in Interval 8:
     0 Line Code Violations, 4390 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 8 Degraded Mins
     23 Errored Secs, 15 Bursty Err Secs, 6 Severely Err Secs, 25 Unavail Secs
  Data in Interval 9:
     0 Line Code Violations, 26 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 4 Degraded Mins
     9 Errored Secs, 6 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 10:
     0 Line Code Violations, 19 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 5 Degraded Mins
     6 Errored Secs, 4 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 11:
     0 Line Code Violations, 13 Path Code Violations
     8 Errored Secs, 2 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 12:
     0 Line Code Violations, 18 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 3 Degraded Mins
     6 Errored Secs, 5 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 13:
     0 Line Code Violations, 5 Path Code Violations
     5 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 14:
     0 Line Code Violations, 136 Path Code Violations
     15 Errored Secs, 11 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
  Data in Interval 15:
     0 Line Code Violations, 107 Path Code Violations
     18 Errored Secs, 13 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 16:
     0 Line Code Violations, 50 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 6 Degraded Mins
     16 Errored Secs, 11 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 17:
     0 Line Code Violations, 216 Path Code Violations
     40 Errored Secs, 20 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 18:
     0 Line Code Violations, 71 Path Code Violations
     19 Errored Secs, 9 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 19:
     0 Line Code Violations, 204 Path Code Violations
     40 Errored Secs, 17 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 20:
     0 Line Code Violations, 228 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 12 Degraded Mins
     64 Errored Secs, 25 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 21:
     0 Line Code Violations, 62 Path Code Violations
     13 Errored Secs, 8 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 22:
     0 Line Code Violations, 39 Path Code Violations
     7 Errored Secs, 4 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 23:
     0 Line Code Violations, 32 Path Code Violations
     10 Errored Secs, 4 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 24:
     0 Line Code Violations, 182 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 11 Degraded Mins
     31 Errored Secs, 17 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 25:
     0 Line Code Violations, 3668 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 14 Degraded Mins
     121 Errored Secs, 74 Bursty Err Secs, 5 Severely Err Secs, 46 Unavail Secs
  Data in Interval 26:
     1 Line Code Violations, 8761 Path Code Violations
     97 Errored Secs, 61 Bursty Err Secs, 7 Severely Err Secs, 93 Unavail Secs
  Data in Interval 27:
     0 Line Code Violations, 10 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 2 Degraded Mins
     5 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Data in Interval 28:
  Data in Interval 29:
  Data in Interval 30:
  Data in Interval 31:
  Data in Interval 32:
  Data in Interval 33:
  Data in Interval 34:
  Data in Interval 35:
  Data in Interval 36:
  Data in Interval 37:
  Data in Interval 38:
  Data in Interval 39:
  Data in Interval 40:
  Data in Interval 41:
  Data in Interval 42:
  Data in Interval 43:
  Data in Interval 44:
  Data in Interval 45:
  Data in Interval 46:
  Data in Interval 47:
  Data in Interval 48:
  Data in Interval 49:
  Data in Interval 50:
  Data in Interval 51:
  Data in Interval 52:
  Data in Interval 53:
  Data in Interval 54:
  Data in Interval 55:
  Data in Interval 56:
  Data in Interval 57:
  Data in Interval 58:
  Data in Interval 59:
  Data in Interval 60:
  Data in Interval 61:
  Data in Interval 62:
  Data in Interval 63:
  Data in Interval 64:
  Data in Interval 65:
  Data in Interval 66:
  Data in Interval 67:
  Data in Interval 68:
  Data in Interval 69:
  Data in Interval 70:
  Data in Interval 71:
  Data in Interval 72:
  Data in Interval 73:
  Data in Interval 74:
  Data in Interval 75:
  Data in Interval 76:
  Data in Interval 77:
  Data in Interval 78:
  Data in Interval 79:
  Data in Interval 80:
  Data in Interval 81:
  Data in Interval 82:
  Data in Interval 83:
  Data in Interval 84:
  Data in Interval 85:
  Data in Interval 86:
  Data in Interval 87:
  Data in Interval 88:
  Data in Interval 89:
  Data in Interval 90:
  Data in Interval 91:
  Data in Interval 92:
  Data in Interval 93:
  Data in Interval 94:
  Data in Interval 95:
  Data in Interval 96:
  Total Data (last 24 hours)
     3 Line Code Violations, 19690 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 161 Degraded Mins,
     582 Errored Secs, 325 Bursty Err Secs, 20 Severely Err Secs, 182 Unavail Secs
______________________________________
Some parts of the config:
interface Serial0/0/0:23
description XXXXXXXXXXXXXXX
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
controller T1 0/0/0
pri-group timeslots 1-24
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
YHZBUR-R0#sh int serial 0/0/0:23
  Hardware is DSX1
  Description: PRI ID 07/IPCD/131808/000/MRTM/000
Frank den Haan
Level 4
Level 4
Just to close this one out, in the end the problem was on the Telco's side. They finally replaced the circuit with a fibre-based T1 and that resolved it.
