T1 signal maximum distance
lolac1234
I'm using a vwic-1mft-t1/e1 in a 2811 router, what is the maximum cable distance between stations?
dgahm
Level 8
Level 8
Carlos,
This data sheet says 6200 feet, but it is going to depend on cable type. Dedicated 110 ohm T1 cable is ideal, CAT 5 cable is good, and running it in 25 pair house cable is worst case.
http://www.cisco.com/univercd/cc/td/doc/product/access/iad/iad2430/hw_inst/2430plan.htm#wp1015267
Please rate helpful posts.
Dave
