Showing results forĀ
Search instead forĀ
Did you mean:Ā
Tacacs configuration for cisco N540 router
poojaryp1974
Hi ,
Please confirm below tacacs configuration  correct for cisco N540X router.Please let me know if you any changes require.It will great help if you can provide your input.
tacacs source-interface Loopback0 vrf default
tacacs-server host x.x.x.x
tacacs-server host y.y.y.y
key 0 abcdef
exit
aaa authentication login console local
aaa authorization commands console none
line console
login authentication console
exit
aaa authentication login default group PCCU-ISE local
aaa authorization commands default group PCCU-ISE
aaa accounting exec default start-stop group PCCU-ISE
aaa accounting system default start-stop group PCCU-ISE
aaa accounting commands default start-stop group PCCU-ISE
Prash
0 Replies 0
