Tacacs / TCP issue - Tacacs access is not working, will only work after telnet to the tacacs server.
deojoseph7
Good day!
We do have this issue in our Tacacs access. Tacacs acess is not working on the router. The affected routers are members of the same vrf.
The tacacs server is pingable and port 49 is open as well as verified via telnet.
However, the TCP sessions destined to the tacacs server are stuck in finwait1.  It's just weird that the tacacs will work for an hour after doing a telnet to the tacacs server using incorrect port or just telnet to the server w/out any ports.
Traffic captured (filtering the traffic between the tacacs server and the rotuer) was already performed and it showed a TCP out-of-order and TCP zero window results destined to the router.
Any thoughts?
RouterA#ping 204.16.x.x
Sending 5, 100-byte ICMP Echos to 204.16.x.x, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/48/48 ms
RouterA#sh tcp br
TCB       Local Address               Foreign Address             (state)
48C9E5D4  10.168.130.65.48136         204.16.x.x.49             FINWAIT1
48CA3290  10.168.130.65.15255         204.16.x.x.49             FINWAIT1
49372310  10.168.130.65.29261          204.16.x.x.49             FINWAIT1
48278AB0  10.168.130.65.47455         204.16.x.x.49             FINWAIT1
492E5D68  10.168.130.82.19978         10.168.130.81.179           ESTAB
4937294C  10.168.130.65.22            204.16.x.x.40681          ESTAB
481B6008  10.168.130.65.19450         204.16.x.x.49             FINWAIT1
4817D534  10.168.130.65.58877         204.16.x.x.49             FINWAIT1
48188244  10.168.130.65.59926         204.16.x.x.49             FINWAIT1
RouterA#telnet 204.16.x.x 49
Trying 204.16.x.x, 49 ... Open
Hello
debug tacacs authentication
debug aaa authentication
test aaa group tacacs+ (username) (tacacs key) legacy
res
Paul
Kind Regards
Paul
Hi Paul,
Pls. see attached file for my debug results.
I've also included the results of "debug ip tcp packet 204.16.x.x".
Thanks Paul!
I'm only able to access the router using local credentials.
RouterA#test aaa group tacacs+ e1053817 password1 legacy
Attempting authentication test to server-group tacacs+ using tacacs+
No authoritative response from any server.
Hello
I can your icmp is successful but is that destination running as a AAA server?
Is your AAA configuration correct, AA method, key etc.. is it pointing to the correct servers?
Possible FW blocking the connection?
show tacacs server
res
Paul
Kind Regards
Paul
Hi Paul,
The AAA configuration is correct, tacacs server & key is correct. This config has been used in other sites as well. Ping to the tacacs server is also successful.
It's just weird that the tacacs will work (for only an hour) after doing a telnet to the tacacs server from the router using an incorrect port or just a plain telnet w/out any ports.
But port 49 is verified open if you do a telnet.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa session-id common
(tacacs will work for only an hour after doing the below telnet)
Trying 204.16.x.x ...
% Connection timed out; remote host not responding
