Taildropped
what does that mean? is it carrier issue or my shapper issue
RP/0/RP0/CPU0:XXXXXXXXXXXXXxxxx# sh policy-map interface tenGigE 0/0/0/19.3164 | i drop
Fri Sep 1 15:58:09.840 UTC
Taildropped(packets/bytes) : 0/0
Taildropped(packets/bytes) : 18772/24242199
6 Replies 6
balaji.bandi
what device model and what IOS code running.
can you post complete output to understand the issue :
and
BB
Cisco IOS XR Software, Version 7.3.2 LNT
cisco NCS540L (C3708 @ 1.70GHz)
and
BB
TenGigE0/0/0/19.3164 input: CSR-CLASSIFY-IN
Class SIGNALING-IN
Classification statistics (packets/bytes) (rate - kbps)
Matched : 0/0 0
Transmitted : 0/0 0
Total Dropped : 0/0 0
Class NETWORK-CONTROL-IN
Matched : 1631/220412 0
Transmitted : 1631/220412 0
Class VOICE-PTP-IN
Matched : 259879/26507658 0
Transmitted : 259879/26507658 0
Class COS2-V-IN
Matched : 716631/1052947575 0
Transmitted : 716631/1052947575 0
Class GOLD-IN
Matched : 124/21156 0
Transmitted : 124/21156 0
Class SILVER-IN
Matched : 181045/267314121 0
Transmitted : 181045/267314121 0
Class BRONZE-OAM-IN
Matched : 826100/1180150452 0
Transmitted : 826100/1180150452 0
Class class-default
Matched : 2201531791/1549162488839 166
Transmitted : 2201531791/1549162488839 166
Policy Bag Stats time: 1693589142216 [Local Time: 09/01/23 17:25:42.216]
TenGigE0/0/0/19.3164 output: CSR-SHAPER-1G
Class class-default
Matched : 9314257892/13256444997465 691
Transmitted : 9314239120/13256420755266 691
Total Dropped : 18772/24242199 0
Policy CSR-EGRESS Class NETWORK-CONTROL-Q
Matched : 0/0 0
Transmitted : 0/0 0
Queueing statistics
Queue ID : 1238
Policy CSR-EGRESS Class SIGNALING-Q
Matched : 66/4488 0
Transmitted : 66/4488 0
Queueing statistics
Queue ID : 1239
Policy CSR-EGRESS Class VOICE-PTP-Q
Matched : 0/0 0
Transmitted : 0/0 0
Queueing statistics
Queue ID : 1237
Policy CSR-EGRESS Class COS2-V-Q
Matched : 0/0 0
Transmitted : 0/0 0
Queueing statistics
Queue ID : 1236
Policy CSR-EGRESS Class GOLD-Q
Matched : 0/0 0
Transmitted : 0/0 0
Queueing statistics
Queue ID : 1235
Policy CSR-EGRESS Class SILVER-Q
Matched : 0/0 0
Transmitted : 0/0 0
Queueing statistics
Queue ID : 1234
Policy CSR-EGRESS Class BRONZE-Q
Matched : 13266343/2121692609 0
Transmitted : 13266343/2121692609 0
Queueing statistics
Queue ID : 1233
Policy CSR-EGRESS Class class-default
Matched : 9300991483/13254323300368 691
Transmitted : 9300972711/13254299058169 691
Queueing statistics
Queue ID : 1232
Policy Bag Stats time: 1693589142245 [Local Time: 09/01/23 17:25:42.245]
Fri Sep 1 17:27:25.824 UTC
TenGigE0/0/0/19 direction input: Service Policy not installed
TenGigE0/0/0/19 direction output: Service Policy not installed
policy is only config on subinterface
you have only drop
Class class-default
what is the usage of the interface ?
sh  interface tenGigE 0/0/0/19 human
BB
Joseph W. Doherty
"what does that mean?"
Generally it means a FIFO queue has overflowed.
"is it carrier issue or my shapper issue"
As the issue is usually caused by insufficient bandwidth, cannot say it's actually an issue of either.
I'll also note, the percentage of drops is such a tiny percentage, it's very unlikely this is an issue, especially as all the drops are in the class-default class which also is normally used for best effort.
