tar, pkg files in router flash
ramon.yu.jr
hi, i am doing an IOS upgrade on one of our remote sites and the router flash doesn't have enough space to put the new IOS in.  Although I can delete the current IOS from the flash and put the new one in, I wanted both IOS to be in there in case the new one has issues when booted up.  I was thinking of deleting the files below from the flash with I believe are only required for SDM.  I just need confirmation before I do so as I haven't deleted these files before in the router flash.  thanks!
sdmconfig-2801.cfg
common.tar
securedesktop-ios-3.1.1.27-k9.pkg
regards,
ramon
Leo Laohoo
Yes.  The files you've mentioned are for SDM.  If you are not using SDM then it's OK to remove these files.
Leo Laohoo
thanks for the confirmation leolaohoo!
Leo Laohoo
Thanks for the ratings.
