vlan config
gavin han
I've folowing scenario:
<<<routerA>>>-----L2 connection---<<<routerB>>>----layer3 connection----<<<RouterC>>>
router A and B are nexus 7K switches while router C is 3750Switch. and router B and C have layer 3 connection.
I've vlan 5 on A which is not defined on router B and router C. so I need to span vlan 5.
what would be best way to span it to Router C?
2 Accepted Solutions
Hi Gavin,
Just to ensure we understand each other - the current diagram - the Layer2 domain is partitioned by the L3 link between B-C. Thus, if VLAN 5 is created on the 3750, it has no relationship to the VLAN 5 on the Nexus. If the L3 link between B-C is the only physical connection to the Nexus, then this statement would stand true for all VLAN's created on the 3750.
So in A--- L2 --- B --- L3 --- C - if you created VLAN 3 on 3750, it would be isolated from A,B.
Let me use an example with IP address - keeping it simple we will assume no management domains/vpc's etc, just basic L2 and L3.
A VLAN 5 1.1.1.1/30 -----L2  ----- VLAN 5 1.1.1.2/30 B L3 2.2.2.2/30 ---------- L3 2.2.2.1/30 C ----- VLAN 3 10.x.x.x/24
In this case, you could static route or use a routing protocol to ensure that A knows about the 10.x.x.x network on the 3750. 3750 would need to know about the 1.1.1.x network on Nexus. Sames goes for any other IP subnets that exist.
Starting point:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_layer3int.html#wpxref79308
Some configuration examples:
http://www.cisco.com/en/US/products/ps9402/prod_configuration_examples_list.html
As you state by design VLAN 5 should be across A,B and C - basically in the same subnet, then C will need to be connected into the A-B topology by Layer 2. Essentially VLAN 5 is in the same "domain" across A,B,C.
Ultimately, it depends what the design needs to achieve.
Eugene.
OK, great!
If that's your ultimate goal, then converting B---- C into a Layer2 trunk link will achieve that. You're on your way to planning a migration!
6 Replies 6
Eugene Lau
Hi Gavin,
Just wanted to check what you meant by SPAN and if it means to have VLAN 5 exist across all devices, what is the requirement for that?
From your current description, I wouldnt see a need to change unless were trying to achieve something.
A---- L2 ---- B <<--- can be a point-to-point interface linke B--- L3 --- C
A-- L2 B could be using a VLAN5 SVI to provide that connectivity where as B ---- L3 ---- C simply uses a IP address on the physical interface. The difference is that A-- B would run a L2 protocol such as STP and B--- C would not. Just a design choice as any routing/IP traffic would still be switched in hardware.
HTH.
Eugene
Yes, I meant to have vlan 5 exists across all devices.
since there is layer 2 connectivity between A and B i can do it by creating layer-2 vlan, correct?
but there is a layer-3 connectivity between B and C. so to get vlan 3 on router C, I'll have to create layer-3 inteface for that vlan? and how do I implement routing for vlan 5?
Hi Gavin,
Starting point:
Eugene.
Thanks for your reply.
My ultimate goal is to that VLAN5 would belong to same subnet.
i.e.
A(vlan5-192.168.1.0/24)---Layer2---B(vlan5-192.168.1.0/24)---layer3---C(vlan5-192.168.1.0/24)
there has been be only layer-3 connection (no layer-2 connection) between B and C.
OK, great!
Thanks. but link between B and C has to be layer-3 only
