how to show connections handle by router
b1723651
Hi All,
I'm making a port based load balance testing, so I want to show connections handle by the router, so I can know if the connection/packet is: from which host/port, to which (remote) host/port, and goes out to which tunnel/interface (of the router).
the router i'm using is 887, but it do not support "show ip socket", is there other commands can help me?
deeply thanks.
johnlloyd_13
Level 9
Level 9
hi,
you can use ip accounting command.
Router(config-if)#ip accounting
Router#show ip accounting
mrdogantr
     Try the "sh ip nat translations".
hth
Muammer
thanks, but I'm using routing not NAT.
gerald.suiza
try using netflow
johnlloyd_13
Level 9
Level 9
hi,
