TCP MSS not working
RobotAjay
Please refer the below topology,
Client >>> Cisco router >>> Firewall  >>> Upstream device >>> server
I have set mtu as 200 in my upstream device  and as exepected when client access the server(http) the packets are fragmented.
However when I set tcp-mss(in my case to 55)on my Firewall, I can see it is successfully shared(updated mss) on 3 way handshake, However I can still see client or server is sending MSS more than 55 which is causing fragmentation.
Is it expected?Kindly help
5 Replies 5
what is Firewall you have is it asa?
MHM
Hi, no I am using fortigate, even if I use a cisco router with the same settings it is not working
Only think make tcp mss not work in both FW and router is you using some kind of RA VPN' so are you use RA VPN?
If you use RA VPN then FW and router not see the tcp handshake and hence can not modify the mss
MHM
No, there is no VPN config, just static route
balaji.bandi
Generally i would not touch on firewall MTU and MSS (until we looking to uplift to jumbo frames)
if you are using as ASA firewall look some guide lines :
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/interface-mtu.html#ID-2076-00000095
Make sure MTU match all over the path for better performance.
BB
