Telemetry issue parsing child policy queues
georgemaged
#                            SERVICE INPUT PLUGINS                            #
[[inputs.cisco_telemetry_mdt]]
transport = "tcp"
service_address = ":5432"
max_msg_size=20000000
embedded_tags = [
"Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics/class-stats/class-name",
"Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/output/service-policy-names/service-policy-instance/statistics/class-stats/class-name",
"Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/member-interfaces/member-interface/input/service-policy-names/service-policy-instance/statistics/class-stats/class-name",
"Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/member-interfaces/member-interface/output/service-policy-names/service-policy-instance/statistics/class-stats/class-name"
[inputs.cisco_telemetry_mdt.aliases]
   cpu = "Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring/cpu-utilization"
   memory-summary = "Cisco-IOS-XR-nto-misc-oper:memory-summary/nodes/node/summary"
   memory-detail = "Cisco-IOS-XR-nto-misc-shmem-oper:memory-summary/nodes/node/detail"
   interface_QoS_In = "Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics"
   interface_QoS_Out = "Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/output/service-policy-names/service-policy-instance/statistics"
   if_stats = "Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/latest/generic-counters"
Logs from Telegraf
System info
Telegraf 1.20.4 , Debian GNU/Linux 10 (buster) Kernel: Linux 4.19.0-6-amd64
Steps to reproduce
1.Cisco equipment details
Cisco IOS XR Software, Version 6.5.3
Version : 6.5.3
2.Configuration in Router :
Router(config)#telemetry model-driven
Router(config-model-driven)#destination-group GROUP1
Router(config-model-driven-dest)#address family ipv4 10.53.225.254 port 5432
Router(config-model-driven-dest-addr)#encoding self-describing-gpb
Router(config-model-driven-dest-addr)#protocol tcp
Router(config-model-driven-dest-addr)#commit
Sensor Groups: Sensor Group Id:S-Group1
Sensor Path: Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring/cpu-utilization
Sensor Path State: Resolved
Sensor Group Id:S-Group2
Sensor Path: Cisco-IOS-XR-nto-misc-shmem-oper:memory-summary/nodes/node/detail
Sensor Group Id:S-Group3
Sensor Path: Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics
Sensor Group Id:S-Group4
Sensor Path: Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/latest/generic-counters
Sensor Group Id:S-Group5
Sensor Path: Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/output/service-policy-names/service-policy-instance/statistics
Subscribe to these sensor groups.
  1. Send these data into influxDB.
Expected behavior
The expected behavior is to be able to parse the different classes in the child policy.
Expected to get all class names related to child class names but we receive only "class default"
Actual behavior
convert only class name for parent policy not child and hence get only all class names for parent (which is class-default) not child policy (which has different classes)
0 Replies 0
