Telnet issues with NAT
mukundh86
Level 3
Level 3
I have a  Cisco 2650 with a simple config as follows:
version 12.3
hostname MaVI_Test
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface FastEthernet0/0
ip address 192.168.50.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet1/0
ip address 1.1.1.2 255.255.255.248
ip nat outside
duplex auto
speed auto
ip nat inside source route-map internet interface FastEthernet1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0  1.1.1.1
ip http server
no ip http secure-server
ip access-list extended internet
permit ip any any
route-map internet permit 10
match ip address internet
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password vinakom
login
end
With this config, I cannot telnet to 1.1.1.2 from outside. But when I change the access-list internet as follows:
no permit ip any any
permit ip 192.168.50.0 0.0.0.255 any
telnet to 1.1.1.2 works. Any reason of this behaviour. I guess it is related to NAT but cant figure out how.
Mukundh
Reza Sharifi
That is the correct behavior.  You should always use specific address prefix and the correct mask
(in this case 92.168.50.0 0.0.0.255) and not any any.
For more info refere to this doc:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml
Hi Reza,
I actually saw this doc. Can you point me in this doc  where  there is an explanation as to why the specific address prefix should be used. I was unable to find it.
Mukundh
