Teraterm is blank
MrD
Hi I am having trouble connecting my pc to a witch using teraterm and a console cable. I am using Windows 7 and have verified the settings in device manager. Currently the switch has a green SYST light but when I open teraterm all I get is a blank screen. I have switched cables but with no luck.
Any suggestions?
chrihussey
Hello -
1- You could try stepping through the different baud rates under the serial port setup. The default for Cisco is 9600, but someone may have changed it.
2- If possible try the console connection on a different switch just to see if it is unique to this switch and validate the operation of your teraterm and console cable.
Those would be the first steps anyway.
Hope this helps
