Termianl Server not working.
mohaneternal
I have implemented Terminal Server connectivity for connecting all devices..
4 of my devices are far than the distance of 200 mts. So I have connected them using fiber media converters, but they are not working.
This is how i have connected.
Terminal Server(RJ45) -----> (RJ45)Media Converter ----------------(Fiber cable)----------------------------Media Converter(RJ45)----------Con 0 (Device)
After configuring the Terminal server, i am able to access other devices except these 4 devices which are connected via Media Converter.
Can someone please help resolving this issue.
5 Replies 5
Ruben Cocheno
connect the fiber to a switch and check if the fiber Up, if not could be a wrong tx-rx cables (try swap them) or a damage Media converter. Damage Media converters are common :(
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
I connected same fiber cables to a switch UP link, then it works fine but doesn't work when connected here.
In that case you need to break the problem in slices and starting isolate the components, with/without the media converter, other equipment,etc
I believe you will find out quickly :)
are you using the right connectors/converters? What terminal server are you using?
http://www.av-experts.co.uk/startech-com-cisco-console-rollover-adapter-for-rj45-ethernet-cable-network-adapter-cable-rj-45-m-rj-45-f-blue.html
When i connected the same port for a laptop it worked fine. but not for consoles.
I am using Cisco 2901 router with 16port HWIC card using octopus cables.
