Terminal server for out of band management
bensonlei
Hi, cisco guys,
May I know which cisco router series will be deployed for the terminal server at present ( and lasting for 5 years in future with cisco support ) ?
Feature:
1. Connect to around 8 remote console/network devices
2. Need Cisco support for 5 years in future
Thanks so much for your recommendation.
you need something like an HWIC-8A or HWIC-16A, which you install in an 1841/1941 ISR, or a 2800/2900/3800/3900 router.
Check Table 5 in the attached document:
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/1800-2800-3800-series-16-port-async-high-speed-wan-interface-card/product_data_sheet0900aecd80274416.html
Hi, George,
These models are end of life products ?
https://community.cisco.com/t5/routing/end-of-sale-and-end-of-life-announcements-1900-series-integrated/td-p/3848544
Any current models recommendation, thx ?
With many thanks
