Terminal server on ISR4321
cmandela
Am trying to setup a terminal server using isr 4321 and the end routers are NCS5504 but am not able to its shows a number of errors, which I will attach.
pieterh
i don't tsee any obvious error messages?
except:
    TERMINAL-SERVER-RASDIKA#r3
    % Unknown command or computer name, or unable to find computer address
    TERMINAL-SERVER-RASDIKA#R3
"r 3" (with space) may indicate you want to "resume" an existing session 3
are you sure that is an existing session ?   try "show session"
als you may think you reference a macro but that does not exist on this device
and last your menu only contains a title, but no further options
From your term server,
Can you try
TERMINAL-SERVER-RASDIKA#telnet R3
If you want to short cut the long command to just R3 you will need to write an alias line in the config
conf t
alias exec R3 telnet R3
end
Hoe this helps
Regards, Alex. Please rate useful posts.
One of the things that I note in the config is that the async lines include the statement no exec. It may not be all of the problem but I suspect that it is part of the problem.
Rick
Big +1 on what @Richard Burts just said. If you don't disable exec on the outbound ports, you will get the routers talking to one another. A reboot or error message from the console of the remote router will make the terminal server think a login session has started on that port, and it will be marked as busy.
