Test Radius
Islam Mohammed
I tried to run test radius command but I get below log in ASR9904
The executable 'test_radius' can not be launched. Error: 'libovl' detected the 'fatal' condition 'No such file or directory'
Mark Elsen
   - Seems a known issue in various circumstances , checkout these bug reports :
                  https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&prdNam=Cisco%20ASR%209904%20Router&kw=libovl&bt=custV&sb=anfr
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
sdroy
The error you’re seeing suggests that the executable or its required files are missing or not properly installed on your ASR9904 router. To address this, ensure your software version supports the command, verify the integrity of the installation for any missing or corrupted files, and consider reinstalling or upgrading the software if necessary.
Shuvodip Roy
