Testin QOS
DialerString_2
Level 3
Level 3
Is there anyway to test to see if QOS is running properly? -Other than contacting the end user and saying "Hey, how's the network?"
We are have MPLS and the ISP has configured QOS on their side. My side is listed below: --thx
class-map match-any APPS
match access-group 126
class-map match-any BGP
match access-group name BGP
policy-map ETMS
class APPS
set ip dscp af31
bandwidth remaining percent 100
class BGP
priority percent 5
class class-default
fair-queue
random-detect
set ip dscp default
int s0/0/0
max-reserved-bandwidth 100
service-policy output ETMS
Joseph W. Doherty
You could verify that packets arrive on the far side with the marking you expect. You can also use a traffic generator to load one or more classes and see if performance for other classes is as you expect. (NB: this can disturb production traffic.) BTW, when running across a cloud, such as MPLS, if you have asymmetrically bandwidth, you'll likely only be able to stress in one direction.
Collin Clark
RTR#show policy-map interface s0/0/0
Serial0/0/0
Service-policy output: QOS-POLICY
Class-map: VOIP-CLASS (match-all)
4006351 packets, 1066579361 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name VOIP
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 512 (kbps) Burst 12800 (Bytes)
(pkts matched/bytes matched) 328285/235833485
(total drops/bytes drops) 17363/22918532
Class-map: class-default (match-any)
7798472 packets, 2555569611 bytes
5 minute offered rate 25000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/219/0
The sho policy-map command shows that the traffic is being classed but it's going through a MPLS system that I have no control of.
