Testing the redundancy using VRRP
bjacob1976
Hi All,
I am testing the redundancy using VRRP in a lab environment.I need your help in fixing this issue.This is really basic stuff,guess am missing some configs for the trunk between Switch-1 & Router-1,Switch-1 & Switch-3.Should I use native vlan?
Can anyone help me out to fix this issue?
Many Thanks in advance
Scenario:Attached.
Issue:I am not able to ping from 10.0.0.2 to 10.0.0.5 and vice-versa,All the interfaces are UP.
If I change the Switch1 to a hub,I can ping the IP addresses.
All switches are Cat6500 series switches with Native IOS.
Routers are Cisco7206
Configs given below:
Router1
interface FastEthernet4/0.200
encapsulation dot1Q 200
ip address 10.0.0.2 255.255.255.0
vrrp 4 timers learn
vrrp 4 ip 10.0.0.1
vrrp 4 priority 254
end
Switch1
interface GigabitEthernet1/1
switchport
switchport trunk allowed vlan 200
switchport mode trunk
no ip address
end
interface GigabitEthernet2/1
switchport
no ip address
end
Switch3
interface GigabitEthernet2/1.200
ip address 10.0.0.5 255.255.255.0
vrrp 4 timers learn
vrrp 4 ip 10.0.0.4
vrrp 4 priority 254
end
interface GigabitEthernet1/1.300
ip address 192.168.0.2 255.255.255.0
vrrp 4 timers learn
vrrp 4 ip 192.168.0.1
vrrp 4 priority 254
end
Router2
ip address 10.0.0.3 255.255.255.0
vrrp 4 timers learn
vrrp 4 ip 10.0.0.1
vrrp 4 priority 100
end
Switch2
switchport
no ip address
end
switchport
no ip address
end
Switch4
ip address 10.0.0.6 255.255.255.0
vrrp 4 timers learn
vrrp 4 ip 10.0.0.4
vrrp 4 priority 100
end
ip address 192.168.0.3 255.255.255.0
vrrp 4 timers learn
vrrp 4 priority 100
end
bjacob1976
Hi All,
Can someone help me on this trunk configuration between Switch-1 to Router-1 and Switch-1 to Switch-3.
hdecreis
Hello Jacob,
AFAICT your trunk configuration seems correct...
1/ What does "show int ..." and "show int ... switchport" returns on Switch1 for the trunking ports ?
2/ Reading your scenario, you need to pass only one VLAN between Router1 and Switch3, why bother with trunking then (unless you have other requirements not listed in your post) ? Anyway, does connectivity is OK when replacing trunk configuration with Access ports ?
Apart from the trunking problem, just a remark regarding the VRRP group numbers: I can see you are using same group number for different virtual routers on the same ethernet segment. As VRRP construct the virtual MAC address based on the group number, this is leading to duplicated MAC addresses. You should use different group numbers within the same broadcast domain / device.
Hope this helps
Cheers
Hi hdecreis
Thanks for your suggestions and time.
1.Show int and show int switchport is given below:
sh int gigabitEthernet 1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0018.7385.fe20 (bia 0018.7385.fe20)
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input 00:00:18, output 00:00:06, output hang never
Last clearing of "show interface" counters 1w4d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
204109 packets input, 22389906 bytes, 0 no buffer
Received 124095 broadcasts (123996 multicasts)
0 watchdog, 0 multicast, 0 pause input
53142 packets output, 13240412 bytes, 0 underruns
sh int switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 200
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
2.You are right only single Vlan 200 is passed between Router1 and Switch3.
I have tried replacing the trunk with access ports,but no luck.
I can reach from switch1 to switch-5 but not to router1,the trunk between switch-1 & router-1 is creating the problem.
Router-1 is Cisco 7206VXR and I cannot set the command as "encapsulation dot1q native" because of the IOS version .Do you think adding this command will solve the problem? Any issues with native Vlan matching?
Once again thanks for your comment on VRRP group numbers,I will change it.
Thanks in Advance
Hi All,
Pl ignore this post.
