tftp copy a directory
brian.kennedy
Is there any way to tftp copy an entire directory off a switch? For instance, I want to grap everything that's in:
flash:/c3750-i9-mz.122-25.SE/html/ (60ish files). I could do them individually, but would like to grab them all at once, but tftp won't let you do a directory as far as I know.
thanks.
thisisshanky
Level 11
Level 11
Check the archive upload-sw command. I am not sure if you can do this for a folder with in flash.
Sankar
PS: please rate the post if it helps!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
