VLAN restriction
subashmbi
Level 4
Level 4
How to restrict the intervlan.rigtnow we are all the vlan have to access.so pls give some idea for the same.
ankurbhasin
Level 11
Level 11
Hi Subash,
One way to restrict is to apply ACL and apply it on the interfaces.
Can you please update how have you configured the inter vlan routing? On layer 3 switch or router on stick model.
If you are using layer 3 switch like 3550 switch you can configure acls so check this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swacl.htm#wp1171606
If you are using inter vlan routing on cat6k switch you can also use VACL to restrict traffic so check this link out
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/secure.htm#wp1039223
HTH, if yes please rate the post.
Ankur
in addition to Ankur's post, a simple way to restrict access between VLAN's would be configuring access lists as in the sample configuration below:
interface FastEthernet0/0.1
encapsulation dot1q 1 native
ip access-group 100 out
interface FastEthernet0/0.2
encapsulation dot1q 2
ip address 192.168.2.1 255.255.255.0
ip access-group 101 out
access-list 100 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip any any
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip any any
For SVI's (VLAN interfaces) the configuration would look like this:
interface Vlan1
interface Vlan2
Nethelper
