TFTP on a CISCO 2700 AP
mathys-meuris
I have a Cisco 2700 Access Point (AP) with no files left in its flash memory. I want to transfer a .tar file to my AP via a TFTP server. I set up a TFTP server with the IP address 192.168.1.1. The TFTP server works fine, as I tested it with another machine on the same network. However, when I try to use it with the Cisco AP, I always get a connection timeout. Below are the configurations I applied to the AP. Could you explain to me why this is not working?
13 Replies 13
you use in test 192.168.1.1 and AP IP 192.168.1.100 ??
MHM
What should I change ? IP address of my Ap cannot be the same than my tftp server
When you attempted to transfer the file were there any log messages/status messages generated on the tftp server?
Rick
Leo Laohoo
TFTP process has not been initialized/started.
tftp_init
mathys-meuris
Hi ! thanks for your answer ! I already do the "tftp_init". I haven't any log in my tftp server
What is this TFTP server, is it a Windows machine?
Is Windows FW up?
mathys-meuris
Solar Wind on windows machine. FW Down
Does the SolarWinds' log show TFTP requests come in?
mathys-meuris
Nothing at all on SolarWInds
That means the AP cannot reach the TFTP server.
Put both of them in the same subnet.
mathys-meuris
Already done. Windows ethernet config => ipv4 => 192.16.1.1 for my pc with a 255.255.255.0 for mask
Can the pc running the tftp server ping the address of the AP?
Rick
