TFTP Server
moses12315
Level 4
Level 4
Where can i find a TFTP server so i can backup my running configuration of the Routers. Does need to be free.
moses
guruprasadr
Level 11
Level 11
HI Moses, [Pls Rate if HELPS]
I have attached (.zip) the "3COM TFTP SERVER" with the POST.
Download and use for the Backup of your RUnning COnfiguration.
Fyi, 3COM TFTP SERVER is the best recommended for CISCO Products.
Hope I am Informative
Pls Rate if HELPS
Best Regards,
Guru Prasad R
vaisharm
Hi Moses,
Here's what I always use and recommend:
http://tftpd32.jounin.net/tftpd32_download.html
HTH,
~Vaibhav
Goutam Sanyal
Level 7
Level 7
Hi Moses,
I'd like to suggest you to use the same which was sended by Guru Prasad. Easy to use and reliable.
Goutam
ftpd32.exe is the de facto standard and is recommended by cisco. It aslo supports options that are necessary with ip phone.
beside, a 3com software hosted into an official cisco forum? Shock and horror!
