The ASA does not seem to be doing ROUTING.
4507 and 3850 do not ping.
I attach the CONFIG_SCRIPT.
Do you know the cause ??
Please help me.
I did not find the cause.
I only believe you.
16 Replies 16
Giuseppe
Yes at a minimum inspect icmp should be added. I sometimes also add inspect icmp error. But the essential element is to have inspection for icmp in the policy map.
Rick
Rick
Thank you for the answers.
The cause was the IP SLA.
Thank you.
