1841 PPPOE - Static ip configuration issues - No Connectivity to ISP
Melvinb1981
Good Day,
Hoping for assistance,
I have a Cisco 1841 Router that i want to connect up to my ISP modem. (They requested my Mac Address of the original Router Not Cisco - I have however cloned the Mac Address to my Cisco router trying to rule that out as an issue - Wanting to use this instead of the ISP provided router.)
I have also tried using both chap and pap , running debug commands this should allow some sort of indication if its an authentication issue but no display of errors.
I have not configured any nat configurations as of yet im literally trying to ping any address within the console port
What has been provided from the ISP side is the following:
  • Static IP Address
  • Subnet Mask
  • Gateway
  • DNS Settings
  • PPPOE Username & Password
Router#show run
Router#show running-config
Building configuration...
Current configuration : 1295 bytes
! Last configuration change at 12:11:18 UTC Mon Jan 2 2006
! NVRAM config last updated at 12:11:06 UTC Mon Jan 2 2006
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FCZ094020LM
redundancy
controller T1 0/0/0
controller T1 0/0/1
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 10
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Dialer1
 ip address *.*.*.* 255.255.254.0
 encapsulation ppp
 dialer pool 10
 ppp authentication pap callin
 ppp pap sent-username ***************@du.ae password 0 *****************
 ppp ipcp route default
ip forward-protocol nd
no ip http server
no ip http secure-server
disable-eadi
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Router#
32 Replies 32
this only works when you put the modem in bridge mode, effectively making the 1841 the edge device.
It would be easier to configure double NAT as below:
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
redundancy
controller T1 0/0/0
controller T1 0/0/1
description Uplink to Modem
no ip dhcp
ip nat outside
duplex auto
speed auto
description LAN Interface
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
access-list 1 permit 192.168.1.0
no ip http server
disable-eadi
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Thanks for the reply but i do not want to use the isp provided router.
Are the ISP modem and the ISP router two different devices or the same device ? I am asking because in your original post you said that you wanted to connect the 1841 to the modem...
So basically you want the Ethernet from the ISP to go directly into the 1841 ?
I have looked at your config again, try and add the lines marked in bold:
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
redundancy
controller T1 0/0/0
controller T1 0/0/1
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip nat outside
ip virtual-reassembly
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 10
dialer-group 1
ppp chap hostname yourname@du.ae
ppp chap password password
no ip http server
disable-eadi
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
Still no joy
Router>enable
Router#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Dialer1                    x.x.x.x      YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Current configuration : 1324 bytes
! No configuration change since last restart
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
redundancy
controller T1 0/0/0
controller T1 0/0/1
 no ip address
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
interface Dialer1
 ip address x.x.x.x 255.255.254.0
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 10
 dialer-group 1
 ppp chap hostname xxxxxxxxxxx@du.ae
 ppp chap password 0 xxxxxxxxxxxxxxxxxxx
 ppp pap sent-username xxxxxxxxxxxxx@du.ae password 0 xxxxxxxxxxxx
no ip http server
disable-eadi
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
end
Router#
turn:
debug ppp negotiation
debug ppp authentication
on, shut/no shut the interface and post the output of the debugs...
No Display at all,
Was thinking something at the physical layer but i doubt it as the cables tested and working with the ISP router
Link light comes on the 1841
PPP authentication debugging is on
Router#debug ppp nego
Router#debug ppp negotiation
PPP protocol negotiation debugging is on
Router#config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#int fas
Router(config)#int fastEthernet 0/0
Router(config-if)#shut
Router(config-if)#no s
Jan 2 13:49:59.531: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state t o administratively down
Jan 2 13:50:00.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne t0/0, changed state to down
Router(config-if)#no shut
Router(config-if)#
Jan 2 13:50:05.315: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
Jan 2 13:50:06.315: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne t0/0, changed state to up
Router(config-if)#
Jan 2 13:50:31.763: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEtherne t0/0, changed state to down
Router(config-if)#
what type/model is the ISP modem ? There must be a physical difference, since on your 1841, there is no exchange of any (PPP) packets at all...
So the Du (ISP provider) piggy backs off the Etisalat( ISP - White Box) assume they have some agreement on sharing the lines
I am wanting to plug directly from the Etisalat Box to the Cisco. I cloned the mac address of the Box Below and applied it to the cisco Router.
I don't understand your physical setup. A shared line ? If there is more than one party in the building that uses the ISP uplink, I am pretty sure they have built in some sort of security (beyond the MAC address) to ensure that only their own (compatible) routers can be connected. I would check with the ISP and ask them if what you want to do is possible at all...
hello
First post you stated this
Then this
Router(config-if)#
Router(config-if)#
Router(config-if)#
So at present the status is you have line protocol down correct?
If so and as this is a cisco box and not the isp's own box, are you sure you dont need a cross-over cable or hardcoded speed/duplex settings? -  has this been tested?
Kind Regards
Paul
I have picked up an issue like this before where i have hard coded the
device and it does not work unless physically changing out the cable to
crossover im not certain why this is happening maybe you would best know.
Ill check software revisions and see if there any known bugs with this
version
Router#show
Jan 2 12:07:52.775: %SYS-5-CONFIG_I: Configured from console by consolepppoe session
1 client session
Uniq ID PPPoE RemMAC Port VT VA State
SID LocMAC VA-st Type
N/A 0 0000.0000.0000 Fa0/0 Di1 N/A PADISNT
0000.0000.0000
this might be on the isp side
Cabling or speed/duplex mismatch
Test both
Kind Regards
Paul
