The Cisco C860 Software (C860VAE2-ADVSECK9-M), Version 15.6(3)M3a issu
vangvc
Hi all,
Please help me to fix the issue with  PPPOE:
  • The logs:
*Dec  1 15:52:26.175:  Sending PADI: Interface = GigabitEthernet2
*Dec  1 15:52:26.179: PPPoE 0: I PADO  R:9c8a.cb5b.608b L:084f.f95c.c165 Gi2
*Dec  1 15:52:28.223:  PPPOE: we've got our pado and the pado timer went off
*Dec  1 15:52:28.223: OUT PADR from PPPoE Session
*Dec  1 15:52:28.227: PPPoE 1404: I PADS  R:9c8a.cb5b.608b L:084f.f95c.c165 Gi2
*Dec  1 15:52:28.227: IN PADS from PPPoE Session
*Dec  1 15:52:28.227: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Dec  1 15:52:28.227: PPPoE: Virtual Access interface obtained.
*Dec  1 15:52:28.227: PPPoE : encap string prepared
*Dec  1 15:52:28.227: [0]PPPoE 1404: data path set to PPPoE Client
*Dec  1 15:52:28.231: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Dec  1 15:52:28.231: Vi1 PPP: Using dialer call direction
*Dec  1 15:52:28.231: Vi1 PPP: Treating connection as a callout
*Dec  1 15:52:28.231: Vi1 PPP: Session handle[DC00000E] Session id[14]
*Dec  1 15:52:28.251: Vi1 PPP: No authorization without authentication
*Dec  1 15:52:28.251: Vi1 PAP: Using hostname from interface PAP
*Dec  1 15:52:28.251: Vi1 PAP: Using password from interface PAP
*Dec  1 15:52:28.251: Vi1 PAP: O AUTH-REQ id 1 len 31 from "Tgfdl-200804-004"
*Dec  1 15:52:28.535: Vi1 PAP: I AUTH-NAK id 1 len 5
*Dec  1 15:52:28.535: PPPoE 1404: I PADT  R:9c8a.cb5b.608b L:084f.f95c.c165 Gi2
*Dec  1 15:52:28.535:  PPPoE : Shutting down client session
*Dec  1 15:52:28.535: [0]PPPoE 1404: O PADT  R:9c8a.cb5b.608b L:084f.f95c.c165 Gi2
*Dec  1 15:52:28.535: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Dec  1 15:52:28.539: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Dec  1 15:52:48.707:  Sending PADI: Interface = GigabitEthernet2
*Dec  1 15:52:52.803:  padi timer expired
*Dec  1 15:52:52.803:  Sending PADI: Interface = GigabitEthernet2
  • Router#show inventory
    NAME: "C867VAE-K9", DESCR: "C867VAE-K9 chassis, Hw Serial#: GMK233501PS, Hw Revision: 1.0"
    PID: C867VAE-K9        , VID: V01 , SN: GMK233501PS
  • Router#SHOW VErsion
    Cisco IOS Software, C860 Software (C860VAE2-ADVSECK9-M), Version 15.6(3)M3a, RELEASE SOFTWARE (fc2)
    Copyright (c) 1986-2017 by Cisco Systems, Inc.
    Compiled Tue 19-Sep-17 00:39 by prod_rel_team
    ROM: System Bootstrap, Version 12.4(20160812:080043) [pallavik-v153_3r_m_throttle-rommon 112], RELEASE SOFTWARE (fc1)
    Router uptime is 27 minutes
    System returned to ROM by reload at 15:15:44 UTC Wed Dec 1 2021
    System image file is "flash:c860vae2-advseck9-mz.SPA.156-3.M3a.bin"
    Last reload type: Normal Reload
    Last reload reason: Reload Command
  • Show run:
  • Router#show running-config
    Building configuration...
    Current configuration : 1585 bytes
    ! Last configuration change at 15:25:47 UTC Wed Dec 1 2021
    version 15.6
    no service pad
    hostname Router
    boot-start-marker
    boot-end-marker
    no aaa new-model
    wan mode ethernet
    ip cef
    no ipv6 cef
    controller VDSL 0
     shutdown
    interface ATM0
     no ip address
     shutdown
     no atm ilmi-keepalive
    interface Ethernet0
     no ip address
     shutdown
    interface FastEthernet0
     no ip address
    interface FastEthernet1
     no ip address
    interface FastEthernet2
     no ip address
    interface GigabitEthernet0
     no ip address
    interface GigabitEthernet1
     no ip address
    interface GigabitEthernet2
     description WAN
     no ip address
     ip nat outside
     ip virtual-reassembly in
     duplex auto
     speed auto
     pppoe-client dial-pool-number 1
    interface Vlan1
     no ip address
    interface Dialer1
     description #Dialer interface#
     ip address negotiated
     ip mtu 1492
     ip nat outside
     encapsulation ppp
     dialer pool 1
     ppp pap sent-username Tgfdl-200804-004 password 0 123456789
    ip forward-protocol nd
    no ip http server
    no ip http secure-server
    ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
    ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
    line con 0
     no modem enable
    line aux 0
    line 2
     no activation-character
     no exec
     transport preferred none
     transport input all
     stopbits 1
    line vty 0 4
     login
     transport input none
    scheduler allocate 60000 1000
    end
0 Replies 0
