The command to put a router to DR
gill.lantz
I new on this and will put a router to DR , how do I know if it already is DR, what does DR stands for?
Is DR a backbonerouter?
What is the command if it isn't a DR?
(I'm using packet tracer)
Answer like you should answer a 5 year old ;-), I'm new and English isn't my native language.
acampbell
Perhaps you can translate this document
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml#t20
DR = Designated router
Part of OSPF operations
By default the DR is elected on the highest RID ( Router Identification)
This can be over powered by using
ip ospf priority
on ospf interfaces
Alex
Regards, Alex. Please rate useful posts.
Thank you, one more question, if I want to put a router as a drouter, can I just write Priority 0 or is it something completly different?
ip ospf priority  0 - 255
If you use 0 the router can NEVER become the DR
If 2 routers are using the command the the router with the HIGHEST priority will
WIN
Router 1
interface f0/0
ip ospf priority 100
Router 2
interface f0/0
ip ospf priority 50
Router 1 will become the DR
Alex
