the decrement of vrrp object tracking?
vcp754467
I'm trying to understand how Virtual Router Redundancy Protocol (VRRP) works but confused by the object tracking.
The document, First Hop Redundancy Protocols Configuration Guide, Cisco IOS Release 15S - Configuring VRRP [Cisco IOS 15.5S] - Cisco , described the commnadline "vrrp group track object-number [decrement priority]" but i'm not certain about the meaning.
does the "decrement priority" indicate that if this tracked object appear then the vrrp priority increase?
Therefore, if configuration "vrrp 9 track 30 decrement 10" is set on a router interface, then the vrrp priority will increase 10 because "object 30" shows up.
and vice versa?
sorry for the dumb question..
vcp754467
(sorry the system posted the content twice...)
pman
in your case:
if track status=down then the VRRP priority decremented by 10
if track status=up then VRRP priority change back to 100
Example:
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.0
vrrp 1 ip 1.1.1.254
vrrp 1 priority 110
vrrp 1 track 1 decrement 20
track 1 interface GigabitEthernet0/0 line-protocol
track is down:
R3(config)#int gi0/0
R3(config-if)#shutdown
R3(config-if)#do show vrrp
GigabitEthernet0/0 - Group 1
State is Init
Virtual IP address is 1.1.1.254
Virtual MAC address is 0000.5e00.0101
Advertisement interval is 1.000 sec
Preemption enabled
Priority is 90 (cfgd 110)
Track object 1 state Down decrement 20
Master Router is unknown, priority is unknown
Master Advertisement interval is unknown
Master Down interval is unknown
track is up:
R3(config-if)#no shut
State is Master
Preemption enabled
Priority is 110
Track object 1 state Up decrement 20
Master Router is 1.1.1.1 (local), priority is 110
Master Advertisement interval is 1.000 sec
Master Down interval is 3.570 sec
