The Internet does not work if the provider is in the L2 port
Edgar481516
Hello! The problem is the following: sometimes the Internet access for clients behind the router is lost (wireless and wired), but from the router itself the Internet is available. If you reboot the cisco router, the problem disappears for a few hours and then reappears. The problem is completely solved if you enable the ISP in the L3 port. Can anyone tell me why this happens? Here is an example of configuration.
interface GigabitEthernet0/1/1
description * Starlink *
switchport access vlan 15
switchport mode access
interface Vlan15
ip vrf forwarding inet
ip address dhcp
ip nat outside
ip access-group outside_in in
service-policy output starlink-dmvpn-guest-silpo
interface Vlan135
description *** SLY ***
bandwidth 10000
ip address 192.168.109.1 255.255.255.0
ip nat inside
ip access-group SLY in
route-map Inet_NAT_Silpo_ISP1 permit 10
match ip address 56
match interface Vlan15
ip nat inside source route-map Inet_NAT_Silpo_ISP1 interface Vlan15 vrf inet overload
ip route vrf inet 0.0.0.0 0.0.0.0 192.168.1.1 name inet
ping vrf inet 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/52/96 ms
Everything will be Ukraine !!!
7 Replies 7
match ip address 56
Are you sure this acl is correct add to your router?
Yes, the acl is good. When i plug starlink into L3 port with the same ACL it works.
This make me think
You use specific IP as next-hop in your static route
You instead
Ip route  x.x.x.x x.x.x.x ethx dhcp
It can that dhcp gw is change and make defualt route not work.
MHM
I am puzzled about this "The problem is completely solved if you enable the ISP in the L3 port". Can you explain this? Perhaps also provide the configuration used for that L3 port?
Rick
Hello Richard thank for your answer!
I have started use this:
L3 port
interface GigabitEthernet0/0/1
ip address dhcp
ip nat outside
negotiation auto
instead
l2 port (swithport)
One more thing check when use l2 of the dhcp push IP or nor
Show ip interface brief
MHM
Thank you for the information that I requested. In comparing what works with what does not work the difference that I find is this:
We do not know what this policy does or how it might affect the connectivity. As a test could you remove this from the config and see if the behavior changes?
Rick
